99 Front Sway Bar Mounting Bolts
Sgt_Morrow
Paragould Arkansas
need to know the size and where i can get some Mounting bolts for my Front Sway Bar, 99 Ford Ragner 4wd 4.0 Off Road Pacakage. Thanks
I don’t know the size. But you can figure it out. Either measure the hole diameter with a ruler. Or, if you have a decent set of drill bits. Use the drill bits to measure the hole. The biggest drill bit that slides through the hole is he bolt size. I’m guessing probably around 7/16” or might be M10 in metric sizes. But measure it for sure. Then just figure out how long it needs to be - the combined thickness of all the pieces you’re bolting together plus flat washers, lock washer and nut. Probably around 1 1/2” or 40mm long for the bracket to frame bolts. I would recommend grade 5, grade 8 if you’re rich. Grade 8.8 or 12.9 metric
