'97 F350 PSD clutch recommendation, now build and whatnot saga :)
This dumb thing needs some love... it's not gaining any horsepower the more I ignore it for some reason...
There's something going on cooling wise, heading home yesterday I was about to the top of the mountain pass doing my normal 38mph in 3rd with the temp at the A in normal then it started wagging a letter then suddenly dropped to the O (I'd use numbers if there were any, you all have Ford's...) over about 20 seconds, I thought something was wrong but didn't have a big cloud of coolant and I turned the heater on and it worked so kept going... it must use coolant temp for fueling because I gained a little power after that and was able to hit 4th...
I'm not sure if the thermostat is now stuck open (although then the temp would fluctuate with load I would imagine) or the temp sender died and it went to some default point? Unless it just blew a chunk out of somewhere that was stuck restricting things?
Ok, I think it's a false alarm, I think there's a bad connection going to the cluster somewhere, the temp going down did coincide with the speedo suddenly stop working (nothing new annoyingly, usually from the oil in the speed sensor connector). I drove it last night when I went to dump the holding tanks and the temp was back in the normal range...
