'97 5R55E to M5OD Help.
97fordrunner
New Richmond, WI
Hey guys, I am looking to do this swap on my truck and I know that a member did a very comprehensive write up on the exact swap he did, I did all the search with all the terms I could think of to no avail as well as a search of the Trans. section in the tech library and come up empty can someone point me in the right direction. Thanks guys.
I had started a write up when I did the swap in my '97, but never got to finish it.
What do you want to know? Ask away and I will answer all your questions.
Thanks a ton, I was thinking it was your write up, Well I was wondering if gen II pedal assembly and master will work on a Gen III, And I need a '97 ECU for sure correct? I have the M5OD and most of the stuff but the pedal assembly for a Gen II.
