RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
- Mar 15, 2009
- Automatic
Okay guru's, I have some knowledge, I'll start first by telling what I have and then what I want to do...
I have a 96 4.0L OHV, 5R55E and 1354E...I have two turbos from 88 T-bird TC's (not sure what size housings, I know they are the same, too lazy to go outside and look right now) they are the IHI turbo's, about 18psi max, a 3" inlet/3" outlet on opposite ends, 14"x30"x4" IC rated at 60psi @ 1000hp with less than 0.2 psi drop across the coils, narrow band AFR, stock ecu, injectors, maf, intake and airbox.
I want to twin turbo my truck, one on each bank (no compound or any of that, not interested, I'm sticking to what I know), I plan on moving my battery to the bed, and removing airbox, so each turbo behind each headlight area. both IC inlet pipes will enter on driverside, exit on passenger side and 90 into maf then TB. I know how to tune the engine to get max fuel out of stock setup (learned by accident modifying exhaust). I plan to drill/tap the top sides of the oil pan, above the oil level of course, and run a tee with 3/8 oil line feed to the twins.
Okay, questions, I believe the stock wastegate is set at 10 to 12psi, will my motor survive, or will I need to upgrade the injectors?? Will injectors from a 5.0L HO (mustang, lincoln, explorer 5.0L) work, or will I need to buy aftermarket?? Can I get away with running without a BOV for a few months?? I have a BOV from another turbo setup I have, its from a 91 talon AWD 2.0L, will that work/should I use that?? I thought about making custom headers, but for now I'll use the inverted stock manifold method. I'm not familiar with the Gen 1 4.0's, I hear they are prone to blown HG's, do I fall into that category?? If I do blow a HG, would using head studs with copper HG's work better?? Do I have to worry about the heads cracking as well, or is that just a Gen 1 prob?? I assume the Gen 1 4.0's were pre OBDII, am I right on that?? I'm sure I'll have more, but this is a start.
