ok the i bent two rods in the engine and had to replace it while the engine was out someone hit the clutch pedal and blowed the throw out bearing apart so i put a new one in it and after i got it running no pedal i bled and bled and guy at the ford dealer told me to replace the master cylinder. so i did. now i have a a little pedal near the floor at the bottom but if truck is running it and u push in clutch it will not go into gear. if u shut truck off put in gear push clutch in start back it dont move if u let off clutch it pulls. i pulled out of the driveway went for second and no deal. went to turn around and couldnt get it in reverse so i shut truck off put in gear u catch the drift right? u can pump and pump and it will not go into gear.
"the i": You do not need a definate article when refering to yourself. "OK, I bent..." is the proper form of that phrase.
"Blowed": This is NOT the past tense of the verb "to blow". To blow is an irregular verb in English and the correct past participle is "blew".
"push in clutch": Here you do need a definite article. "push in THE clutch".
"It don't" This is an incorrect conjugation. The correct third-person past tense of "to do" is "doesn't or does not". Don't is the first and second person conjugate.
Puctuation and capitalization: Learn them and use them, properly.
Now, on to the mechanical problem. You didn't bench bleed the system properly before installing it. As such you have almost no chance of bleeding all the air of the system before your leg muscles build up to be the size of Arnold Schwartzenager's arms.
Go to Sears, get a hand operated vacuum pump (I understand you are from Tennessee, no your mother's Hoover will not work for this procedure), and then open the reservior cap, hook the pump to the bleeder valve, and pump it up to make sure your seal holds at least a little. Then open the bleeder, re-seat your vacuum nipple, and pump away. Close the screw, pump the pedal 20 times rapidly, refill the fluid and repeat. Do that four or five times and you should be good to go.
