'94 XL Sport - Dark Plum
Featured Build Threads
PoodlePuncher
Forum Member
Firefighter
Twin Ports
WI - USA
Vehicle
Drive
2WD
2.3L
This is my 1994 XL Sport, in Dark Plum, with the optional Sport Graphics.
I've only ever seen one other like it, and that was at a dealership back in 1995 (full story in my Introduction post)
Ran a vin report, and found out it only had a Single owner.
only has 156k on the clock.
Today i washed away all the "Farm Grime", to get a better idea of what i'm dealing with
I was suprised at how much shine the old finish still has.
I didn't wax it, but i may need to
The kid i bought it from, said it had been living it's life hauling firewood, and the drivers side bed tells that story well
The worst of it
PS Bed isn't quite as bad.
I'd normally just replace the bedside, or swap another bed, but i'd really like to save the decal...
That's a problem for future me
Inside the bed is actually really good. it's perfect candidate for a spray in liner.
Inside was really gross when i first brought it home.
let it air out for a few days with the windows down, and then attacked it with the vaccum today...
The Rodent smell has faded a bit, but is still present.
The seats may be salvageable, but the carpet needs to be completely replaced.
Once i can manage to get the seats out, i'll pull the carpet, and every interior panel i can remove.
will give the cab the deepest clean it's ever had.
Looks like a good starting platform. Maybe it is the angle of the picture, but the right rear axle looks to be set back an inch or two from the front of the fender opening.
y is ur name PoodlePuncher tho?
Where's Nelson's "nuke the whales" poster when you need it?
And you're the one asking silly questions? :)
To be more on topic that doesn't really look that bad, some ham fisted body work should get that less bad in no time, my '97 took some "turd polishing" to get straighter then I just give up and attack it again when it bugs me...
I'm only home a couple days a week, so i finally had some time to get this thing running...
I knew it needed a starter (it was already removed), but when i got under the truck i realized why the kid likely gave up on it...
Every terminal on the starter was broken off, and hanging under the truck.
and to make matters worse, he broke the O2 sensor in the process...
The other end of the battery cable was also in terrible shape, so i opted to replace it rather than try to repair it
The lug on the battery cable is 3/8", which is too big for the terminal on the starter, so i replaced it with one that is 5/16"
If you're going to do something... do it right.
Perfect fit.
I'm out of double wall shrink tubing, but this will be fine until i can get more.
The O2 sensor was pretty easy, with the starter out. Just hit it with my cordless impact wrench, and it came right out
didn't even have to drag over an air hose.
The starter however, was a PITA. it took several tries, but the bolts were fighting me something fierce...
Since i didn't remove it, i'm not 100% sure these are even the correct bolts...
the threads are m10-1.5, so that checks out...
but one is not like the others...
I ended up chasing the threads both in the holes, and on the bolts themselves
This helped immensely, but the long bolt just seemed too long
no matter which hole i tried, it felt like it was bottoming out.
so i replaced it with a cap head bolt i had on hand (bottom).
With the starter in, and the wiring repaired, i hooked up the battery...
This is when tragedy struck!
when i connected the negative cable there was MUCH sparking, and a huge plume of magic smoke was released from this area
This is clearly the wrong battery, as the posts are reversed
but i didn't think to check, since it came with the truck, and the cables only reach so far...
Pretty sure i smoked the ECU, as it's one of the few things that gets power with the ignition switch off...
Hooked up a (almost dead) jump pack, and the lights still work, and the starter did engage.
I did not hear the fuel pump, but i could've missed that.
Will get a good battery, and cross my fingers.
but there was a lot of smoke. A LOT!
So... I got the new battery.
i can hear the fuel pump prime, but engine rotates slow when starter is engaged.
first try: Smoke appears near the firewall center.
Second try, Smoke from what appears to be every ground location...
went to remove the negative cable from the battery, and it's hot to the touch...
Here's a video of the whole ordeal.
guess i'm gonna have to tear this down and inspect the wiring.
sounds more like a winter project, than a quick get it running situation.
if i take it apart, there's gonna be a whole host of "while i'm in there" stuff to tackle.
Here's what i know
1. electrical systems are working, including lights, accessories, and fuel pump...
2. Truck was able to run when bump started
3. engine rotates slowly when starter is engaged
4. Grounds heat up and smoke when starter is engaged.
applying a bit of electrical theory, everything points to the negative battery cable.
Reasoning:
When the starter is engaged, it's essentially a dead short, drawing ~150 amps (or more).
1. this is way too much for the chassis grounds to handle (hence the smoke).
2. the chassis grounds can't provide enough current for the starter to operate properly (slow cranking)
and sure enough, the negative cable is completely seperated at the block.
This likely explains why the old starter completely melted down.
the heavy wire between the solenoid and motor completely disintegrated.
The negative cable was due for a replacement.
the jacket had several spots worn completely through, and the broken end was about what you'd expect
Replaced the negative battery cable.
The starter is much happier, and no more smoke from the grounds
it currently doesn't start, but clearly is getting fuel (i can smell it)
Next, will have to determine if there's spark, or if the ECU got damaged in the earlier blunder.
it was a long rabbit hole to travel down, but i managed to get it on the road today...
After replacing the starter, and the battery cables, the engine was still rotating very slowly...
confirmed proper spark from both coil packs
Noid light showed the fuel injectors were recieving proper signal
spent last weekend scratching my head...
Then the light bulb went off... the kid made a point that there was a new serpentine belt...
Popped off the belt, and sure enough, the alternator was frozen solid!
With the belt off, the truck fired right up
With this new information, i have pieced together what happened...
1. Negative cable separated from the block, causing a very restrictive load through the body grounds...
it would've been slow to start, but drivable (only an issue when starting)...
2. He was probably driving it that way, when the alternator seized up.
the added strain on the engine, plus the lack of a direct to engine ground, is likely what caused the starter to melt down...
3. He said he bump started it to get home, and that's probably when the belt gave up.
Side Note:
during my troubleshooting, i noticed, all of the spark plugs on the passenger side were finger tight, so he probably pulled them at some point
now that i've been able to drive it, I've identified the following issues
  1. The exhaust system is shot. its leaking from basically everywhere, and one of the EGR tubes is rotted off (small one that goes up to a box on the firewall).
  2. The suspension is ok (ball joints, tie rods, etc.), but it definitely needs shocks, ASAP.
  3. it's very difficult to fill with fuel. i only put in half a tank, but had to run it at the slowest setting (which took forever). any time the pump would go full flow, it would kick off immediately.
    Probably vent related...
    also, found a puddle under the truck after filling, so it appears it was leaking from the fill tube, whenever the fuel got backed up...
  4. The frame is pretty crusty. not surprising for the area, but seems solid from what i can tell.
    sometime soon, will remove the bed, to better inspect it...
    can knock out 2 & 3 while it's off.
  5. The shifter is sloppier than a spoon in a bowl of warm pudding...
    "Vague" would be a significant upgrade.
    Also, the clutch is nearing the end of it's life.
    still works, but engagement is all the way at the top of the pedal.
Upcoming TRS Events
Featured Ranger Based Vehicle
