94' B3000 2wd
Deano3000
Murphy NC
I'm new to the forum and not sure if I am putting this in the correct spot but what the hell I a owner of a 94' B3000 2wd and am in the process of lowering it but run into a slight dilemma this truck has IBeams and not Tbars im a working man and plain and simple can't afford 3" drop beams I have the 3" drop coils was told if I put those on it'll cause my front end to toe can anyone possibly explain to me or direct me in the right way on how to compensate for this I've heard camber bushings but not a mechanic idk what else to do im doing all the modifications myself at home in my garage all and any insight is greatly appreciated thanks in advance
Welcome to TRS :)
Bookmark this page: https://www.therangerstation.com/tech_library/index.shtml
Loads of "been there, done that" articles for Rangers an B-series
Check out the "suspension" section and "Mini-truck" section for specifics on lowering your truck
The physics of lowering a vehicle in the front is more complicated than the rear
The spindle is what the wheel rotates on, a vehicle maker engineers it so the spindle will be parallel to the road when suspension is assembled, and when steering it stays as close to parallel as possible
If you change the suspension angle then you change the spindle angle, like so: https://cdn.shopify.com/s/files/1/2597/3112/t/9/assets/camber-diagram.jpg
So spindle is no longer parallel to the road, its angled up, if lowering vehicle
This leaning in, or out, is called Camber and stock suspension has small adjustments to do Wheel Alignments so tires don't wear more on the inside or outside of the treads
But its not enough to lower the suspension down very much
So to lower a vehicle you need a way to make the spindle parallel to the road again
