94-97 5 speed
You're getting there.
If you end up with an extra rubber shifter boot, that's good, and you want to sell it, please keep me in mind.
The shifter don't come with the transmission? How much was the 5 speed and drive shaft
A SuperCab? I would have been looking for a single piece driveshaft from a newer Ranger to eliminate the center bearing, a u-joint and a bunch of vibration. (All SuperCabs have same wheelbase, transmissions end at same point, so length is determined by 2 or 4wd. You might need correct yokes at axle*, but otherwise it should just fit)
*Given it is is SuperCab, axle should have the larger plate anyways, but this is Ford...
The transmission,shifter,driveshaft was 240$ The wiring harness floor plate for 5 speed, 2 speedometer gear assembly 2 shifter accessory mounts 1 with cup holder 1 no cup holder ( just the square mounting ring for shifter boot) 2 shifter boots,clutch/brake pedal assembly was 40$
Ok members,
Anyone have a line on pressure plate bolts that will fit in the LUK flywheel?
I hate to go back to pick and pull to drop a transmission for a set of bolts for the pressure plate. I may make a trip anyway just to go ahead and pull another 5 speed and get all the needed bolts and a 5 speed to have spare parts if needed.
Ok members,
I think in a pinch there would be no problem just using regular bolts from the hardware store. I don't recall if they are SAE or metric though but they are about 1/2" long. If you can get grade 5 or 8 or 8.8 metric, with a flange head, that is what I'd use... or a regular bolt, washer and blue lock-tite. I probably would not use a lock washer on that application.
My ACE Hardware has a great selection of Metric an SAE bolts and they also have grade 8 and of course they will be getting a drop of blue on them. I am just trying to get as much together before I start tear down as I can.
