Anyone able to give me some feedback on where this leak may be coming from? (see attached picture)
Initially found a leak and couldn't tell where it was coming from. Believed the thermostat was stuck and thus caused undue pressure causing a leak on lower coolant hose on water pump. Thought I saw some fluid coming out on top near water pump. Went to drain the radiator and maybe 4 cups of coolant came out. I just replaced the thermostat housing, filled the radiator and started the engine and this leak was revealed.
