96fordrangerxlt3.0
- Apr 14, 2013
- Automatic
I have a 96 ranger and the old engine died, I bought a 94 3.0L as a replacement knowing ill have to swap parts from the old 3.0 to the replacement. I know the 94 has a different ignition system. So my question is, what besides the cam sensor and crank pulley/crank sensor need to be swapped? Obviously ill have to put my 96 harness on the replacement, but I'm not sure of what else I will need to do if there's anything ill have to do besides the parts swap I just stated. I believe the 94 3.0 has a bolt hole for the crank sensor but I don't want to jump the gun and assume that it will bolt right on with no trouble. I would believe ford made the timing covers with the bolt hole knowing ahead of time that they would be using the newer style ignition so that they can use the overstock timing covers from the 94's to the 95's and it would be very likely they built this 3.o in the later part of the year when all the design was finished for the 95-97 rangers and probably was for the last of the 94 rangers and had the new timing covers, the same way that my cab and frame was built in november of 95 and was finished in 96, I know manufacturers will do this sort of thing to prevent over producing parts and assymblies. Maybe I'm wrong but I think this is the case and hopefully I can swap without changing the timing cover.
