93 Splash in SC, V8-Swap version
That is what I did
Then I brought it back because when they had it on a two post lift they didn't know the front diff dropped and the driveshaft rubbed. :fie:
Then when i swapped to a telescoping driveshaft I had to totally remake it because it did not fit at all. :annoyed:
Mine wraps around the bellhousing (added plus any ATF drippings from transmissions dribbled down the bell onto the exhaust for disposal) not the oil pan.
What oil pan is that? I am not sure my foxbody pan has enough room to do that. Does it heat the oil?
Its Foxbody dual sump. Pretty sure it was a Dorman: https://www.summitracing.com/parts/rnb-264-022/make/ford/model/mustang/year/1982
Never had any heats issues, I run conventional 5w-30 Valvoline and change it every 3K. Truck runs 195-200* on a hot day with AC cranked and single core rad. I dont have an oil temp sensor, but there is no signs sludge or goo in there and it typically looks almost new when I change it.
