saling4
- Feb 5, 2008
- Age
- 69
- 1988 Ranger 2.3
History: 1989 Ranger 2.9 xlt ext cab 190K miles
running great until it Overheated and cracked a head (Broke a heater hose on freeway).
Okay so I tore it down put new gaskets and heads new vacuum hoses, etc.
Back together and running fine just a little rough, but drivable.
After about 10 miles it starts overheating (new radiator and thermostat, radiator cap).
Pull out thermostat and it is not opening. Drove it without TS for about 100 miles. Ran fine just didn't seem to have the power it used to.
All of a sudden it gets real loud and check engine light comes on intermittently.
Replaced TS with a new 180*,
Pull it in garage and check timing first....Wowsa, I had it set at about 10* ATDC. Reset to 10*BTDC. No change in running smoothly...still loud as heck. Found big hole in muffler so now I know why it got loud.
Pulled codes and the only ones were KOEO 29, 41. Didn't worry about the 29, but the 41 leads to the O2 sensor.
Pulled O2 sensor and did the bench test with a torch. Heat up and it goes to .9 take heat away it drops to Mv's quickly. Hmm, seems good.
Put O2 sensor back in and connect meter. Start truck and it goes to .8 to .85 volts and stays there. Pull vacuum hose and idle increases, but voltage doesn't change or goes up (I thought it should go down).
After running for 20 min's I found that the radiator water is still cold.
Checked for codes and there are none.
So I guess my question is what now?
This time I will check whatever you gentleman suggest and post results until I get this solved. So this may go on for awhile.
