- Oct 17, 2016
- 2.9L
- Automatic
Ok, thanks.Throttle pedal problem, mine does that if the kickdown cable for the auto trans gets pushed around a little. I just wiggle it around until the pedal feels good again.
The picture looks like a pcv valve with an extra vacuum tap. Mine has that and the extra vacuum tap is plugged on the end. If you need the extra tap you are supposed to cut the end off of it before you put a vacuum line on it.
I looked all around the engine bay and I couldn't find anything unplugged or loose. Just took it for a test drive and it just has no guts. Bringing it to mechanic shop tomorrow, things have moved past my knowledge. My grandpa thinks it's the cat, which it may be. Just gonna let the mechanic figure it out.
Sent from my SM-G950U using Tapatalk
