89 bII A4LD question
miles
Saskatchewan,Canada
hi guys just wondering if anyone has had this problem before and hopefully what the cure is my trans works fine except the first shift from first in the morning it wont shift untill its ready but after that first shift it work great. any ideas guys thanks.
Sounds like low fluid. Get it warm and then with the engine running at idle, and the truck on a level surface check the fluid level and condition. If low, adjust it to a proper level. If dark/dirty pop the pan off and put a new gasket and filter in and then re-fill it, or take it somewhere to get flushed.
sorry i should have said that i just replaced the front seal and the trans is full
also the trans was doing this before the new seal with no leaks when the seal went it just blew in one shot thanks again
