aeidian
- Oct 7, 2010
89 2.9 4x4 odometer reads 16793 (its either 216 or 316k for sure)
Lately the old truck has been sluggish to start. Battery tested and alternator tested and starter is a couple months old. Just did cap and rotor and wires. I believe the culprit to be just end of life on the motor. I bought this used and done a lot of work to it. The oil pressure has always been terrible. At warm idle it hits about 700rpms and about 7 psi on the oil pressure gauge. Pretty much 10psi per 1k rpm. Ive been told that's not great but acceptable. I'm aware it "should" be much higher. You cant really rev the motor over 2k because it rattles and taps pretty bad. Keep it in the 1k to 2k and its pretty good. Cold starts it rattles and taps bad for the first 5 seconds then smooths out. I made the mistake of letting my sister use my truck over the past week and she didnt realize you shouldn't go over 2k on the shift and she was doing 3k+. I'm sure that shortened what time I had left. The other night she was driving it and killed it and it took a half hour of jumping it to get it to start and when it did there was a loud tap from the passenger side valve cover area. After about an hour of solid driving it went away and it was smooth running again. Once today I killed it and it was the same thing, it just would not turn over with much gumption. It feels like the motor is trying to lock up. Earlier than this it would start after sitting and I was able to turn the crankshafts over a few turns with a 19mm and a breaker bar and it fired right up. I'm pretty clueless to the internal of the motor, is the tapping from the valve cover that smooths out after running a lifter? Could that be causing my poor oil pressure? A stuck lifter? Ive replaced the rear main, valve cover, and oil pan gaskets. The front main looks like its still leaking. Suggestions?
Sent from my SCH-I405 using Tapatalk 2
