- Aug 23, 2014
- Automatic
My 88 ranger is no longer starting, ill try to keep this short. I don't really have any mechanic experience so please bear with me. A few months ago it began having problems starting. It would turn over but not start, but if i kept trying then after a few minutes it would, sometimes it would stay on and sometimes it would only idle for a few seconds and shut off. But if i kept at it then it would eventually start and stay on, then I would start to drive it and it would not go over like 15mph and sometimes sputter or shut off while driving and I would have to re-crank it but after a few minutes of driving it would drive like normal.So for a while I was thinking the fuel pump was going bad (not sure if it has anything to do with it but I feel like this all started to happen after I used some fuel cleaner, my thoughts were maybe the cleaner knocked some junk loose and was causing problems). Now it will not start at all, wont even turn over. Radio and dash come on in with the key in the 2nd position but in start position nothing happens. . Since it no longer starts at all I have replaced the starter(which was a pain in the ass because I didn't have a jack) and solenoid because I thought I might have burnt it out with all that cranking but that is not the problem, and tonight I went ahead and changed the ignition switch because I had problems with it before that were resolved previously with a zip tie. Tonight I went ahead and bought a new fuel pump and was just going to bite the bullet and try to look up how to change that myself also but don't have the torque bits to take the bed off which the guy at auto zone told me would be necessary to get to the tank. But then I started thinking that if it was a fuel pump issue wouldn't the car still be turning over and at least still trying to crank? So much for keeping that short but any help would be greatly appreciated.
