88 XLT Ranger
- Jul 23, 2010
- Age
- 63
- Pollock Pines Ca
- Automatic
I've bled brakes several times using a one-man bleeder kit ($10) and have had great success. With these kits you do not need to hold down the brake pedal at all. Just hook up the hose, crack the bleeder, and pump the pedal a few times...no more needed...just sit back and watch the bubbles...and top up the MC as needed.
The reservoir on them actually sits higher than the brake cylinder which totally baffled me as far as gravity and all that...but the air bubbles float upward...doh! Works great and you can do it all by yourself.
Which reminds me...I still have to get driver side hooked up and bled...![]()
One man bleeder kit? where did you buy that from? my help never showed up so I did the crowbar and 2x4 pump it push it agenced the brake peddle. I got a good drip flow from both sides no bubbles. The peddle did come up felt hard even started with booster was up. I shut it off for few minuts started it back up same deal right to almost the floor just front brakes working. If I push the peddle quick the back brakes work for a second than fade away fast. I wonder if its the Master Cylinder like the mechanic said?
