88 XLT Ranger
- Jul 23, 2010
- Age
- 63
- Pollock Pines Ca
- Automatic
Viper or anyone question?
I orderd the solenoid kit from Napa with 3-4 shift and converter lockup. Do you have to remove the valve body to change them and can the valve body gasket be re-used is it possable to get it off without tearing the gasket. Napa you have to buy the full rebuild kit to get the gaskets $154.00 I tried Napa and Cragan to get a single valve body to trans gasket with no luck if you gone through this need help
I got 175,000 on it only issue is slipping out of gear when letting off the gas over 25mph or higher. You coast back down to 25mph and it clicks back in gear. We figured its the converter lockup solenoid or an issue with both solenoids "cross my fingers"
