87 ranger xlt hub issues
Featured Build Threads
lewiusmc93
hi i recently bought an 87 ranger xlt 4x4, was replacing the front passenger side bearing and notice the needle thrust bearing, bearing spacer, and the axle shaft spacer are missing. mine are auto locking hubs WITHOUT an inner and outer spindle nut. the spindle nut on there is a hex nut, not a spanner, and instead of an outer nut to hold torque, there's a small key that slides under the nut. i was wondering if anyone knew if the needle bearings, washers and shaft spacers come with new hubs, or anywhere i might be able to find that stack-up. i'm considering converting to manual hubs but i need at least the axle shaft spacer to do so. any help is appreciated.
Featured Ranger Based Vehicle
