87 Ranger Driveshaft Swap
Featured Build Threads
Roaming Shores
OH - USA
Vehicle
Drive
2.9L
So I have an 87 ranger 4x4 supercab which originally had the two piece driveshaft, but driving home one day it blew apart on me so I read all the discussions on here and purchased a one piece from a 02-11 4x4 supercab ranger(which was said to work) and I installed the 1330-1310 U joint flanges and installed on truck and drove it a couple of days no issues, then started to get a vibration. The front piece of the shaft that slides in and out was barely catching the splines by half an inch. So now I'm not quite sure what to do, I need 62" from center of U-Joint to center of U-Joint(Measured when installed). Any help would be appreciated, Thanks
Interesting.
What manual transmission do you have? (Hint, the tech pages on here have pictures and all).
I don’t remember the measurements, but some of the earlier transmissions were shorter than later ones. I did the 98-11 driveshaft swap on my 92 but it was an auto (A4LD) which is the same length as the later transmissions so I just had to swap a yoke.
If its a 7.5 rear end that would also make the driveshaft potentially come up short. I have an aluminum and a steel one piece shaft for sale in central ohio that I could do some measuring on as well.
Interesting.
Pretty sure its the FM145
Yes it is the 7.5 rear end, that would be great
FM145 is one inch shorter than the M50D trucks that swap works for. If the 7.5 axle is shorter too, then you're potentially 2" too short on driveshaft.
I wonder if you could get away with a spacer (like a wheel spacer) on the pinion flange?
They make them. Mustang guys use them when doing manual swaps
Yeah I tried looking for spacers for the 7.5 and could only find them for the 8.8. Do you know where I could find them at?
7.5 vs 8.8 doesn't matter, it's just about figuring out what Spicer calls that bolt pattern and finding a spacer for that spec. The pattern isn't even specific to Fords
Or.. embrace the snowball. 8.8 swap and M5OD swap lol
Upcoming TRS Events
Featured Ranger Based Vehicle
