Burnside
I have been tossing around different ideas for front suspension setups.
So I've that the explorer rear leafs are the hot ticket for the front of an RBV.
If I go this route it will, with no intention, be the ultimate budget build.
One conflict I potentially see with that setup is the spring perches that exist on my dana 60 are 3" wide. Explorer leafs are 2.5" wide.
Would this be an issue? Having a 2.5" wide leaf on a 3" pad? If so how can if be corrected? Would something need thought up to take up the gap between the spring pack and u-bolts? Could I notch the casting with a grinder to move the u-bolts closer? What are my options? Or is this even an issue?
-Cheers, Josh.
-Cheers, Josh.
