85_Ranger4x4
Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- 5.0L
- Manual
Forgive me if I messed it in this thread, but does the passenger side header clear the frame without cutting?
It fit really nice, having my engine sitting an inch higher on that side than where the convertable mounts would put it helped too. I did it for oil pan clearance (a non-issue I guess on a 2wd) but it helped the header vs framerail situation too, it would have been tight without it. That whole crossmember is different in ways I am not sure of 2wd to 4wd though.
One thing I don't really like about them is the #7 tube hugs is on the inside of the header making it really tight for the engine oil dipstick. Mine is kind of wedged in there, very slightly pinched between the header and block (we will see how that goes I guess) The actual swap header has #7 to the outside of the header and should give it more room for the dipstick. The pipes get all clustered together for the collector right in front of the dipstick port on the block, so you can't just go around the headers without getting a horrific bend in the tube. For the Comet/Falcon that the 88400 was designed for with the dipstick in the timing cover it wouldn't have been an issue.
88400
89500
So I think the perfect set of swap headers for my application would be the DS of the 89500 and the PS of the 88400
If I was doing a 2wd I would go with the Shelby tri-y's, they need a little tweaking to fit the 164t bell but they also fit really nice. About the same price as the Hedmans too.
If anyone has anything on making t-case linkages don't be shy. People are always mixing and matching them and I doubt they are crawling under the truck to shift them manually. I have a C5 tranny and a BW1350M for those that haven't been paying attention.
