84 ford ranger
dont know if anyone can help me ,but if you could i would sure apprecate it cant set the camber on my truck ,purchesed ajustable bushings ,no luck new lift kit 5.5 superlift new radius arms to
so what your telling me is with a 5.5 superlift i have to cut my axle housings to correct the camber ? the ajustable sleaves wont correct it ?
If your putting a level on the rotor it needs to have the weight of the truck on it.When you have a jack under the arm it changes the leverage ratio against the spring which gives you a higher ride height and throws off your camber measurement. You put your wheel back on roll the truck back and forth a few feet for your ride height to be right.Tape a torpedo level to a straight stick that fits across the wheel your measurement will be more accurate.If I could get the camber close at all I would drive it for a few days new springs can settle which will change your camber too.
