I have a 93 ranger 4.0L V6 2wd with auto transmission. My rear axle is shot so I ordered one from a local salvage yard. I have the 8.8 with 308 gears, open diff and 10" drums...I ordered the same rear axle out of a donor truck with 64k miles. They delivered it free of charge to my work address.
After I brought it home I wiped off the grime off the tag on the diff cover only to discover that it is a Limited slip rear axle with 373 gears. It is still the 8.8 with 10" brakes, so it should bolt up no problem.
I'm assuming they simply sent me the wrong one, which means that I have no idea how many miles the donor truck had, however it does feel good. I haven't yet pulled off the cover to see what it looks like inside.
Other than the speedo being off (I used the calculator in tech section to determine how much off it is), are there any other issues I could run into with this install? I know I will have better low end torque, worse fuel economy, and more traction... For the kind of driving I do with this truck (it basically hauls my mountain bike around on and off road and in the mountains), I think this is probably a step up over the open diff with 308's.
