- Aug 4, 2020
- Toledo, OH
- 2.3L
- Manual
- Tire Size
- 235/75/R15
I have a 1996 Ford Ranger (Reg Cab, 2.3L, 5spd, 3.45 rear axle) unk mileage. It originally had the stock 195/70R14 tires on it and could go 80+ pretty easily (never went over 80 due to poor suspension and suspect tires). I needed to replace the tires and had some 15" rims decided to upgrade and got some heftier tires (235/75/15) and now it is very sluggish when trying to get up to speed on the hwy and peddle to the floor on flat ground it can maybe get up to 70mph (2500rpm). I knew the bigger rims/tires would have an effect on the performance of the truck but didn't think it would be this drastic. Is the tire upgrade the cause of this poor performance or is there somewhere else I should be looking? Work that has been done:
- All fluids, front to back, have been changed.
- Spark plugs and fuel filter have been changed.
- Fuel pressure tests said it was in the acceptable range but on the low side.
Am I at my limit with the 2.3L engine and 3.45 rear axle? Not looking to put a bunch of money into it and just using as a daily driver.
