6 Inch Lift Questions
Which 6 inch lift kit is better?
  • BDS
    Votes: 0 0.0%
  • Rough Country
    Votes: 0 0.0%
  • Total voters
  • This poll will close: .
Tbow2025
New Addition
⭐Supporting Member
Hendersonville
TN - USA
Vehicle
Drive
2.3 EcoBoost
285/75R17
6 Inch Lift (cost is not a concern)
Also, what shock package would you choose? What upper control arms? Anything else that would be good to incorporate into these kits.
Have you looked at the parts list for each kit and the instructions to see how the lift is achieved and what all the parts in the kit are for? They clearly have different pieces from each other.
I see a lot of positive reviews on the Rough Country lift, but the only review I saw for BDS was someone complaining that their front differential cracked a year after the install.
Out of those 2 choices, I think I like Rough Country better. It appears that they probide different struts. But the BDS kit is just supplying spacer blocks for the existing struts.
Both seem to supply lift blocks for the rear leaf springs, which I'm not comfortable with. It would be wise to skip those and order 6" lift leaf springs from Skyjacker or have some built at a local spring shop.
I've never really held Rough Country in a super high regard. :dntknw:
There's not much choice for a 6-inch lift. Skyjacker designed a 6-inch but never released it. I've always had the impression that BDS was the cheaper of the cheap lifts.
Regardless, I'd love to follow the build thread if @Tbow2025 installs a lift on his Ranger.
It's been a while since I looked at BDS or heard anything on them. They did seem to have a decent reputation at the time.
Rough Country has gotten a lot of heat for the quality of their lift kits.
So, it seems to be a roll of the dice as to which to get. Like mentioned above, take a hard look at the components to decide which might be the better gamble.
