- Aug 11, 2007
- Age
- 38
im currently building my 8.8 (31spline of course) and im havin difficulties getting the right gear pattern.
to start:
pinion shim stock 30 thousandths
30 thousandths on 5.13
gear mesh showed pinion to deep or close to carrier
changed shim to 25 thousands
gear mesh showed same, to close to carrier
shim change to 0, no shims at all
gear meshed showed to close to carrier.
all 3 appear to be exactly the same, the randys ting and pinion guy doesnt listen i gues and sais to go with 26 thousandths.
changed shim to 50 thousandths
gear mesh showed to close to carrier (no suprise there)
all readings were taken with back lash within 12 to 15 thousandths, spec calls for 11 to 16.
im lost, i sent pics to randys we'll see what they say.
has anyone done 5.13s on a torsen? im using yukon gears and yukon master install kits.
anyone had any experiance with the torsen?
to start:
