on my '83 4x4, Tri y's didn't fit. The main issue was the front driveshaft, i didn't see any way around it, but luckily i have 60's mustangs too, so that's where i'll use them. your truck looks great by the way.
shifter location isn't as bad as I thought it would be. doesn't look like much trimming needs to be done there.
looking great so far!
i like that trans crossmember. too bad my mount is different, i'm going to have to go custom
i bet your tranny will come forward another inch or 2
How did you get the passenger motor mount out? The space is so tight I cannot get a wrench of any sort into the space.
Thanks for the reply. I was in Knoxville today and went by James Duff and talked to them. They are some pretty cool cats. They said lift the front passenger wheel off the ground so the suspension would hang and it should give you a little more room. They were right and as you said...persistence was half the battle. It's off and I'm getting ready to install the new mounts I bought from Duff. Again, thanks for your help and keep the photos coming of your build.
