While I know that this is not an uncommon issue on the RBVs, here's the issue:
Before it got cold I was having issues with the automatic hubs in that they wouldn't lock in when the xfr case indicated 4Hi or 4Lo. I got the hubs working fine and at the time wasn't having any issues with the truck going into 4wd. Everything was working fine which is how I wanted it to be prior to using it this winter.
Today we got snow and it had gotten a bit slick out.. only a few inches of snow. I thought I'd just put it into 4Hi. Well, of course it didn't work.. I got the old 6 flashes of the indicators every 2 minutes.
After pouring through the troubleshooting guides and all the other threads having to do with the flashing indicators; I checked the fuses, knowing that I changed out the motor and that everything was working last month I found a post stating the in some cases the problem was cured by disconnecting the battery, letting it sit for 15 minutes and then reconnecting. After I reconnected the battery and started the truck, the 4x4 worked without a problem. Amazing.
