burn0ut
- Jan 29, 2010
- them hills in wv
- My credo
- not here for a long time, only a good time... AFFA
ok so im aware this has been posted before ive dug through alot of the search results but i jsut cant seem to narrow my problem down, i dont have cash to go fixing maybes.
so heres my problem, every 2 minutes my 4hi 4 low flashes liek everyone elses, theres no noises or anyhting else going on other than flashing those lights and my 4x4 doesnt work. i turn the switch nothing whatsoever. no click no click nothing. i took my t case apart and other than the plastic on th ebackside being cracked where my dumbass friend put there smacking it with a hammer trying to make it work. would htis affect it? i didnt thin it would since it seems to just be a cover of some sort.
also ive checked the 20a fuse under the hood its good. im not real good with voltage meters and dont seem to fully understand testing my GEM module. but im willing to try.
also it has auto hubs, could the vaccume cause the 4hi 4low lights to flash liek this? if so would the howto on making your hubs locke din at all times help?
im starting to go crazy setting here in wv with all this snow and no 4x4 to get out
