Servekaos
Hi guys, I've been lurking for a good long while but now I have a few questions I could use a hand with. Yes I've searched, yes I've checked the Tech Library, yes I've checked other forums/Google.
I've got a '99 4.0L OHV that has about 85,000 miles with a persistent cylinder 3 misfire CEL. It will go away periodically and then come back. I haven't noticed the truck running poorly but then I could just be used to its behavior. All plugs/wires are new (~9 months) and the coil pack was replaced about 6 months ago. I had a persistent vacuum leak that left me with banks 1/2 too lean which I eventually traced down to the fuel filler neck. Since I've replaced that the lean codes have not returned. That was about 6 months ago.
I've noticed that it seems to be leaking oil from the underside of the engine if I crawl underneath. Additionally I've been getting slight white smoke from the exhaust, which I know is normal at startup but (I think) it seems to have a slight sickly-sweet type of smell which I suspect may be coolant. I had all my fluids topped off about 2 months ago and I've noticed my coolant tank is only about half full now.
Now I know about the infamous head cracks and the upper/lower intake manifold gaskets but I wanted to get a few opinions as to what I might be dealing with. This truck only has 85k on it which strikes me as a little early to be developing cracks in the head. Around what mileage do they typically develop, assuming normal operating conditions?
Thanks guys, the help is much appreciated.
