4.0 idles better with MAF unplugged
Featured Build Threads
Acgallen
5+ Year Member
PA
I have a slightly modified 1992 4.0, bigger throttle body, injectors and MAF housing. I had the original setup working before it came out and went into the Bronco 2, so i used all my original parts. ECT sensor reads in range, as does TPS. Out of the 3 MAF's i have, my 5.0 MAF responds best to throttle(Which was the original MAF). It almost idles like it has a cam, but when i unplug the MAF, it idles like a dream. Since i swapped into a 85' B2 i have no Tachometer to tell yall what my idle RPM's are. If i could post a video, i have comparisons of the idle. Im sure RonD has probably solved this a few times but i cannot seem to find a forum that has this issue. Honestly its not a huge deal, but it does get a little annoying to have to keep it alive when cold starting. Runs and starts like a dream when warm. TIA
That tells me the problem is the MAF. When it's unhooked the PCM defaults to speed density programming and runs fine.
Event Coverage
Featured Ranger Based Vehicle
