- Aug 7, 2007
- Opelousas La.
- Manual
the 390 is like the most expensive ford engine to build........it's parts don't interchange much=expensive
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Apparently you've never actually added the costs up. Do they cost more than the small block ? Yea.. Are they the most expensive? NO. It also depends on what you're starting with, and where you're going with it.
"does it cost more than a small block........" more like does it cost more than all the other big blocks?
edelbrock performer for the 390 $286 http://www.summitracing.com/parts/EDL-2105/
same one for a 460 $224 http://www.summitracing.com/parts/EDL-2166/
same one for a 351 cleveland $213 http://www.summitracing.com/parts/EDL-2665/
the exact same manifold for a 302 $159 http://www.summitracing.com/parts/EDL-2121/
so in this example the 390's manifold costs 80% more than a 302, 28% more than a 460, and 35% more than a 351 it appears that you got it backwards i have added it up and you haven't
i mean:
go ahead compare pistons, camshafts etc. for yourself
You conviently ignored the sentence about what you were starting with, didn't you ?A couple years ago I bought a 58,000 mile 68 Merc Monterey. It had the premium fuel 390 2 bbl motor in it(10.5 to 1 compression). My kids ran it for a few months, then we pulled it to rebuild it. All it needed was two pistons replaced (I had an extra set of these...390 flat tops) swapped the cam out for a Crane 272* Energizer ($125 thru Summit, with the lifters) Swapped the iron 2 bbl intake with a 428 PI unit (bought that one for $250) Also bought a set of FPA headers for the car (that was the most expensive part, but cost no more than any other custom header does @ $430 delivered) New rings, bearings and gaskets ran about $150. Total was less than many other rebuilds I've done. Point here is you do not have to buy all new off the shelf parts to go fast. A little shopping around here and a 390 cost no more than any other motor to build. If you're doing a 427 or 428, then yea, it's gonna cost you more,(if you don't shop around) than a 390 or any other motor. So, no I didn't get it backwards
Just think of the currently popular 383 Chevy as a reborn 390 Ford. Pretty close to the same bore and stroke. Hell the distributor hold down clamp is even the same.
"owned"? seriously? the stereotype of ford guys being stupid is hard to ignore at this point
you "ignored the first sentence of my post".....idiot i just merely commented on how the 390 is "the most expensive ford engine to build" and what i said is totally and irrefutably true. due to lack of interchangeability the 390's parts are more expensive prove me wrong seriously "own" me for real i dare you to prove it apples to apples
aftermarket heads for a 390 $745 http://www.summitracing.com/parts/EDL-60069/
the same heads for a 460 $656 http://www.summitracing.com/parts/EDL-60699/
the same heads for a 289/302/351w $579 http://www.summitracing.com/parts/EDL-60259/
ok i was going to compare crankshafts next but summit doesn't even offer a crank for the 390 hmmm
you used pistons in your post that "owned" (ha ha ha still makes me laugh) me so i'll do pistons next (i just picked the cheapest ones)
390 $21.39 http://www.summitracing.com/parts/STL-H304P20/
identical pistons for the 460 $14.69 http://www.summitracing.com/parts/STL-H418P/
identical pistons for a 302 $12.69 http://www.summitracing.com/parts/STL-H654P20/
the pistons are 68% more than a 302, and 45% more than a 460
all the parts are this way i don't feel like chasing links just to show someone who is too stupid to understand basic vocabulary (because you obviously didn't comprehend my first post despite its uncomplicated plain wording) and basic math (you know that $21 is more than $14......apparently not) but you're not expected to..........you're trying to defend the 390 doesn't that say enough?
oh and your 390 vs 383 comparison, if you want to go ford vs chevy the price difference is even larger more still those same pistons at $10.39 http://www.summitracing.com/parts/STL-H580P/ the 390's pistons cost 105% more
OK, genius, whatever.
a swing and a miss with this guy... he's a lost cause but it looks like everyone else gets it
