347ci with A/C having cooling issues
Featured Build Threads
Roanoke
VA - USA
Vehicle
Drive
5.0L
Hi all,
Just purchased an 84 short bed 2wd with a 347ci sbf hooked to a t5 and a 8.8 rear. It has air conditioning on it so there’s a condenser in front of the radiator. Radiator is larger than stock and it has a pusher electric fan on the condenser due to having zero room on the engine bay side. 160 Thermostat is in it and working correctly. My question is how can I keep the heating under control? It can’t set in traffic long without running the temp up to around 215. I can’t fit a larger rad in due to the condenser. Is there a fix for this issue?
Thanks in advance
heating up sitting in traffic is an air flow issue, need a better fan set up or a remote condenser with it`s own fan unit.
pusher fans are not as efficient as puller fans. would it be possible to mount a puller fan or a mechanical fan with a shroud ?
the old hot rodder that helped me had a few rules for mechanical fan set ups.
1. if the radiator is 20" wide a fan 18" or 19" in diameter is needed
2. the fan blades must be half way inside the shroud & a minimum of 1" from the radiator. use a fan with wide blades.
3. be sure the air flow cannot get around the sides, top or bottom of the radiator.
No room for a puller fan setup. My next move was to get a larger higher cfm fan, just wanted to make sure I’m headed in the right direction. I haven’t been out to look but I wonder if I can’t move the condenser and radiator forward enough to fit the fan on the correct side
If you're not running the Explorer front accessory set up already, give that a hard look.
What radiator are you using? Two fans will help a lot. Explorer front dress and a Northern V8 swap radiator will give you room for that but you may then lose room for your AC condenser and pusher fan.
215 is really not very hot in the grand scheme of things - does it keep climbing or does it just stay at 215? A lot of "modern" vehicles run at 210... my Jeep and most newer GM vehicles I've had always sit right around 210. My V8 swapped truck with pusher/puller electric fans and no AC will see 210+ often if I am wheeling it hard or driving at highway speeds. The cooling system continues working until it starts boiling and that is somewhere around 250-260 degrees. I don't even worry about 210 any more, only until it hits 220-230 do I start thinking about letting it cool off.
My thermostat is 196F. 210F is probably where mine runs. I've only ever used the stock gauge.
relocate radiator and condenser forward. put a Taurus type fan behind it.
this assumes you cleaned or know that the radiator and condenser are free of debris and flowing air ok .
i open the core support up and push the radiator far forward as possible.
25x19 aluminum radiator cools well
Featured Ranger Based Vehicle
