Thanks Mark.
By the book my floor isn't thick enough. The owner's manual says to use 5" wedge anchors. The neighbor and I were talking the day I brought the compressor home and we figured the floor probably wasn't any thicker than 4", so I got 3.25" anchors, which means I needed 3.5" holes. I went clear through on at least one of the holes I drilled, so we will see how that holds up. I'm most worried about water coming up through, the garage is technically in a flood zone but has had the ground around it graded and raised to get it "out" of the flood zone. One of the other anchors just isn't holding in the floor, but so far I haven't had any real issues related to vibration. She doesn't walk or make undue noises. In fact the worst thing I have run into so far related to compressor vibration is the nut that holds the drain on my water separator keeps falling off.
Anyway, picture time:
Here is my full setup, as it exists now:
60 gallon 11.5 CFM compressor unit, regulator and drier, all Kobalt from Lowe's.
From there I ran a soft line (which may get replaced with hard pipe at some point) up over the rafters and attached it to a 25 FT auto-retracting reel. All hoses are 3/8" ID.
Some point in the future, when money is less tight, I want to get a second reel and put one at the front of each bay of the garage but for now one in the middle will do.
I've also picked up a sander and paint gun in the last few weeks. Go check my truck's build thread for details about that.
And then just to show off, my tool boxes:
