2010 ranger xcab auto 2wd... looking for lift options
sd
Have a 2010 ranger xcab automaitic and was wondering if I have any lift options available?..... appreciate any help and if someone has done this to thiers would be great to see a pic or two........thanks
Depends on how much you want to spend and how much work you're willing to do. What size lift are you looking for? What size tires would you like to run?
This is my 05 2wd with a fabtech spindle lift, pa body lift, shackles and a torsion crank on 33"x12.5" tires
Before the body lift
Hope this helps!
appreciate the reply....i'm looking for a lift about as high as yours but im really not sure my 2.3l could really pull those 33's so probably 31's instead.....is yours a body lift or suspension lift?
No problem man. The top picture is a body lift and suspension lift (8 inches of lift). The bottom picture is just the suspension lift (5 inches of lift). You don't need to go much higher if you just want to run 31's. Grab some 2" lift blocks and 2" coil spacers then you're done!
yeah im thinking about 4-5" of lift would be good...did you go with new spindles and spacers to get your 5" of lift in the front?...and just new brackets for the springs on the rear correct?
Spindles and cranked the torsion bars in the front, add-a-leaf and shackles in the back
