Beetlejuice
Hello,
I have searched high and low for the "consensus" tap location for switched power on a 2009 Raner (I assume most gen 3 would be fairly similar, if not 2008+). I am planning on adding a Dashcam AND a USB charger for phone on this same tap, with tap kit, like seen below.
I understand that a wire could be run from battery, relay used with switched power, and a new mini-hub for new fuses. BUT... isn't there a good Fuse in the Cab to use?
I found the following Diagram and Key at https://www.autogenius.info/ford-ranger-2009-fuse-box.../
Fuse Ampere rating / Description
1 5 Instrument panel dimmer switch
2 10 Trailer tow park lamps
3 10 Right low beam headlamp
4 10 Left low beam headlamp
5 5 Windshield wiper module (RUN/ACCY)
6 10 Radio (RUN/ACCY), Door switch illumination
7 — Not used
8 10 Restraints Control Module (RCM), PADI (Passenger Air bag Deactivation Indicator), Occupant classification sensor (OCS)
9 5 Cluster air bag indicator
10 10 Cluster (RUN/START), 4×4 module (RUN/START)
11 10 Smart Junction Box (SJB) (Logic power)
12 15 Audiophile subwoofer amplifier, Satellite radio
13 15 Horn, Interior lamps
14 15 High beam headlamp, High beam indicator (cluster)
15 — Not used
16 30 cartridge fuse Power windows
17 15 Turn signals/Hazards
18 — Not used
19 20 Center High-Mounted Stop Lamp (CHMSL)/Stop lamps
20 10 Anti-lock Brake System (ABS) module, Speed control module, Back-up lamps, Overdrive cancel switch, Electronic flasher (turn/hazard)
21 5 Starter relay coil
22 5 Radio (START)
23 30 Headlamps (low and high beam)
24 20 Radio battery feed (B+)
25 — Accessory relay (power windows)
26 2 Redundant cruise switch
27 10 Climate control blower relay/blend doors
28 15 4×4 module battery feed (B+)
29 20 Cigar lighter or power point, Diagnostic connector (OBD II)
30 5 Power mirrors
31 20 Front park lamps, Rear park lamps, License plate lamps, Dimmer switch, Trailer tow park lamps
32 5 Brake switch (logic), Brake-shift interlock
33 5 Instrument cluster battery feed (B+)
34 20 Power point
35 15 Power locks
7 — Not used
15 — Not used
18 — Not used
22 5 Radio (START)
30 5 Power mirrors
34 20 Power point
35 15 Power locks
