2006 FX4 Daily / Offroad Build
The next thing to go over is the seats for the truck.
First the rear seats were removed to give more room for something. Not sure yet but want to explore more storage or the sub mount. I really want to keep the floor available. That's for way down the line though.
In one of the first post pictures of the Explorer Limited I pulled from the junkyard was shown and in some of the more recent post the seats might have been seen actually installed.
Well it has been an ongoing process because it was my initial goal to swap over the electric tracks, lumbar support and heated elements to the Ranger seats. While I knew back then the Explorer seats were better all around, I really was trying to figure out how to keep the Ranger as factory looking for items from the Ranger. This ended up being a lot time and effort with not the results I was looking for.
So been riding around in half bolted in Explorer seats and for the last year or so I have a single wire from the battery to the seats while I figure out the wiring and how I want to power them permanently.
Showing the attempt of trying to get the Explorer elements transferred to the Ranger seats. The reason I wanted to use the Ranger seats is because they are in way better condition and to try to avoid the cost of upholstery.
I do think it would be possible and I did get the electric tracks attached but in the end it was becoming unnecessary work. With enough time and some fab work it could be done but since I don't have as much time as I thought for the project and also no welder the end decision was to just use the Explorer seats.
After getting the Explorer seats back in because I got them from a Limited they came with the memory function. Still haven't got it to work yet, so hoping for some help from here on the wiring.
I can get the switch to light up but can't get the seat to move from the switch. It moves from switch on the seat but not memory. Not sure the issue because I have two different memory switch and I doubt i would have two that are not working. Just going to have to keep playing with the wiring.
Getting close to all the updates done on the truck in posts! Then it can be real time updates.
Couple of small things that aren't huge but still work done. Swapped out the license plate lights with a set of Morimoto. Morimoto to me is the best light brand out there right now. I have all my F-150 lights swapped to Morimoto.
I got another junkyard find which was a STX grill. Only issue was the surround was white and broken. Started working on gluing it and then plastic welding but got lucky again and their was a black surround in the junkyard a couple months later. It has a weird bump in the center but nothing a heat gun can't fix. I have it mocked up and roughly attached to the truck but before it is fully installed I want to paint the STX grill with Raptor liner. Getting the STX part of the grill was a pain in the ass especially when you don't want to break anything, so before it is snapped in forever I want to get it looking right.
Realized I don't have a picture of it on the truck, will get one this weekend to show it. I have always really liked the STX grill, so super happy to have it and avoid painting the surround
Another small item working on in the background is swapping out the faceplates in the instrument panel. Mine are black but now with the all black interior it feels like it is blending in. I pulled a white set and need to get it swapped in to see how it looks. What i really want are the silver accent that came on the FX4 Level II.
Or maybe pull the trigger on something really different like this 🤔
After completing the 07+ window and lock swap the next goal was to get the auto up and down wired in. I only have two modules right now for the passenger. I got them temporarily mocked up with alligator clamps and it worked!! The only thing which it seems to be common is the auto up is very touchy. I don't think anything can be done about it and just will take a little to get use to.
Unfortunately it paused after the mock up because I wanted to make the harness and connections a lot more clean and less of a rats nest. I have extra random wire from other harnesses but I like to make my life difficult and they need to match the Ranger's wiring lol. So finally went to the junkyard and pulled a whole door harness so I can depin the auto up/down module have all the wires cut exactly to length and soldered in.
Here are the temporary wiring for the auto up and down for the passenger side. This is still not completed but will have it done in the next couple weeks.
Even through the auto up and down is still not done there is still have a couple updates that have been done and then the thread is all caught up and in current stuff can be shown!
That looks just as complicated as my 4.0 swap was...
The write up for the Auto Up and Down did say it turns into a rats nest! Since I am making a new harness from the modules I am hoping to make it a lot better looking
Finally got the picture of the STX grill, it still needs to be painted though
Finally at the last update to be caught up on everything completed on the truck and its current status.
Really its just a few small things. I swapped out the Ranger rearview mirror for a the Explorer auto headlights. I don't have it hooked up because I am still holding out and hoping I find a Bronco Eddie Bauer overhead console before I do the whole auto headlights and overhead console mod
Other few small things done was got the radio swapped out for one with Car Play, then did some investigative work on adding an OEM fuse box to where older Ranger's had it on the drivers side.
The last thing was painting and swapping in a Sport Trac dash piece around the instrument cluster. This has a switch that has an auto headlight and fog light option in the switch. Haven't got the wiring figured out but the dash is installed.
  • 2006 FX4 Daily / Offroad Build
