2005 sable ffv pusgrod into a 93 ranger
well.... i finally broke down and bought a MAP gas torch and changed out that o2 sensor on the right bank. so far so go.
I'll let you guys know how it goes later.
i still have the KOEO code 565
but KOER codes are 111
btw, im getting at least 22 mpg
when you crank the engine over is it smooth or does it drag?
after you crank the engine over can you smell fuel in the tail pipe?
did you replace the timing chain. were the t9iming dots aligned together, not both on top or bottom.
if all this is true, rotate the distributor rotor 180 degrees....
please post back the results!
Rob
fail O2 sensor on the right bank, some MAP gas and a wrench to remove it and and the same procedure to install it and I'm running like and ace.....
I wont even mention the amount of cash i spent on other crap i changed out!!!!
Again EARL344P Kudos!!!!!!!
