2001 ford ranger xlt what other ranger years would have compatible parts body wise?
SlugStang8997
California
I need a driver and passenger door and a driver seat for my 2001 ford range xlt.
Fourth Generation 1998 - 2003. Most parts should crossover.
Also, check this string.
It's about ten pages long, but your info may be in there.
Thanks for your reply
The door locks have been broken into on the driver and passenger side of the truck. They look JB Welded back in place. Would i have to replace the entire door to fix that? Or can someone do a more professional job like a welder or something. The owner before the owner i bought the truck from had the break in and it does not look like they got the doors professionally fixed. The door locks don't lay flat, they stick out a little and it is obvious that there was something done to the truck. It could be a bondo job on the door locks it looks terrible enough that i would replace the doors.
The truck i have is the Ford Ranger XLT i think, flareside or step side. It has the suicide doors in the ext cabin. That won't make any difference with door fitment will it. So your saying any 1998-2003 ford ranger xlt should fit so the bed trim doesn't matter when it comes to doors.
The doors are actually the same up to 11, but the mirrors changed and the inside trim panel is different - but you could swap those if you find a later door.
@SlugStang8997
As far as replacing the doors vs fixing them, that of course, depends on the "damage" and your skills (willing to learn) etc.
A couple of images would help a lot.
Doors are not hard to replace. Alignment can be a little tricky, but it's manageable.
Assuming your Ranger has power windows and locks, your donor doors would need to have similar options so the harness would have the same plugs/wiring.
Obviously keys would be different.
Doors are not that expensive if you get 'em from a you-pull.
But, please post some pics of your doors and the condition of the locks that were JB'd in place.
