2001 3.0 smoke test, any pointers?
I will try that.
I did run another smoke test and had a lot of smoke coming from the charcoal canister. Dropped the spare and the canister and the new vapor canister vent solenoid was leaking profusely. I had the old one, installed it and no leak. So I took it apart, sealed it with some silicone and did another smoke test, no leak. But interestingly, when I did the smoke test, it built a ton of pressure in the gas tank, I saw some gas vapors residue by the gas cap, removed the cap and a huge woosh of pressurized air came out. I assume thats a good thing?
I can't see how that happened unless the smoke tester pressurizes the intake somehow...
There was a slight amount of smoke coming from the top of the gas tank, but I assumed it was a pressure vent valve. I may just have to remove the bed and get a closer look at the fuel tank itself. That will mean grinding off some seized bed bolts.....
As I stated earlier, the vent valve is normally open and closes only during evap leak check. If you had not pinched off the line or electrically closed it during your test, smoke coming from there would be normal. There is no pressure vent valve on top of fuel tank, smoke from there is not normal during your smoke test!
Yep, I need to drop the tank and run another smoke test. I'll have to plug a lot of hoses, but something isn't sealing there. I'd remove the bed, but with seized bed bolts, thats a heck of a chore.
Grinder with a new grinding wheel, not a Zip disk. Grind straight down in the middle of the bolt, grinding wheel held at a 90* angle to the bed. Widen the slot slightly until the head comes off if it doesn’t separate just by grinding down.
