2001 3.0 smoke test, any pointers?
I will try that.
I did run another smoke test and had a lot of smoke coming from the charcoal canister. Dropped the spare and the canister and the new vapor canister vent solenoid was leaking profusely. I had the old one, installed it and no leak. So I took it apart, sealed it with some silicone and did another smoke test, no leak. But interestingly, when I did the smoke test, it built a ton of pressure in the gas tank, I saw some gas vapors residue by the gas cap, removed the cap and a huge woosh of pressurized air came out. I assume thats a good thing?
I can't see how that happened unless the smoke tester pressurizes the intake somehow...
There was a slight amount of smoke coming from the top of the gas tank, but I assumed it was a pressure vent valve. I may just have to remove the bed and get a closer look at the fuel tank itself. That will mean grinding off some seized bed bolts.....
I used the hose from the purge valve going back to the gas tank.
As I stated earlier, the vent valve is normally open and closes only during evap leak check. If you had not pinched off the line or electrically closed it during your test, smoke coming from there would be normal. There is no pressure vent valve on top of fuel tank, smoke from there is not normal during your smoke test!
Yep, I need to drop the tank and run another smoke test. I'll have to plug a lot of hoses, but something isn't sealing there. I'd remove the bed, but with seized bed bolts, thats a heck of a chore.
Grinder with a new grinding wheel, not a Zip disk. Grind straight down in the middle of the bolt, grinding wheel held at a 90* angle to the bed. Widen the slot slightly until the head comes off if it doesn’t separate just by grinding down.
Well filled the tank, drove 240 miles, well below half a tank and no check engine light. Happened 100% of the time before replacing the vapor-canister purge valve. I think this new part obviously wasn't sealing good, thats why so much smoke leaked from it. Sealed it good with black rtv and no more smoke and for now, no more CEL. One thing to note, I did do a KAM reset after the last code clearing I did.
vapor canister purge valve? Are you saying you replaced the vent valve in the back or the forward purge valve under the hood? 😊
Sorry, solenoid on the vapor canister.
Well well well. Dumb people should not work on vehicles. Tackled my last smoke test today that showed a leak at the fuel pump retaining ring. I was able to get all 6 bed bolts out successfully after several days of Seafoam Deep Creep and a Rigid impact. Bought a new gasket and retainer ring from Napa for $24. Upon removing the fuel pump, you guessed it, no gasket at all! No wonder I keep getting a P0455. Installed new gasket and retaining ring, smoke tested and all good. Hopefully this cures it. Also, when I bought this truck a year ago, the only part the guy said has ever been replaced, by his father in law, the fuel pump......this makes 2 times in 2.weeks for a part left off a vehicle of mine. Last week I replaced ball joints and tie rods on my 2019 F250 dana 60 front axle. The dealer put a new driver side hub on in as part of their inspection. Well guess what, they didn't install it with its o-ring seal. Good thing my kit came with them.
I have to admit, I had to reread this entire thread. Did you not have the fuel pump out earlier on this?
No, I was going to replace the gasket, but the smoke was coming out of the top of the fuel pump, so I put some black rtv around it and it stopped. Then it was then canister solenoid leaking, got that stopped, then the area under the fuel pump retainer ring was leaking, although not horribly. I had to remove the bed to replace the gasket eventually anyway, well that day was today.
Good news is I have Forscan updated and going to live monitor tomorrow and see if everything is working correctly. It has bidirectional capabilities.
Event Coverage
TRS Merch
