Hello all,
I have been searching for an answer for this for what feels like hours. I can find plenty of examples of 4x4 Rangers being 5.0 swapped or manual 2WD being 5.0 swapped but not 2wd auto swaps. So here is my question:
I'm currently looking to buy a donor ‘98-‘01 Explorer/ Mountaineer (PATS be damned, but I'll just have Ford match my key), to do a 302 swap on my 2000 Ranger 2WD. Since the 5.0s came with AWD transmissions in literally all the ones I’ve located, what has to happen to either keep my truck 2WD which I’m fine with, or to convert it to AWD which would be awesome but I’m fairly certain it is not possible with it being a 2000 2WD?
My guess is that I can use the 4R70W trans from the Explorer/Mountaineer but just not hook up the transfer case. But then what would go in the place of the transfer case at the end of the trans? And wouldn't it throw a code on the ECU I pull from the E/M when the trans is missing the transfer case?
