- Oct 1, 2021
- Ingleside, Tx
- 4.0 V6
- Automatic
- Tire Size
- 31.5
Was working on the truck and it starts up and shifts in and out of all gears fine. Goes into park, revers and drive with no problems.
the problem comes when I go to turn the key all the way back, turning off the vehicle and trying to get the key out. The ignition cylinder will not turn all the way to the off position in order to allow the key to be taken out.
there is not a switch on the side to allow it to turn like my ‘99 had either. The symptom is the same as if the vehicle were in drive and you turned the key off and it will not allow you to turn it all the way back. But this is doing it in park. I have taken the cylinder out and turned the key that way, but this leaves the vehicle in the on position and all accessories running.
Any ideas?
Any ideas?
