2000 5.0 Explorer Swap Into 98 Ranger 4.0
I will be the test subject. I just ordered them. I got 15.00 off on ebay. I paid 478.00 shipped to the door. These will be going in a 98 4x4 torsion bar ranger.
Please let us know all about them when they arrive and you get them installed.
I’m on my way to the scrap yard with the trailer I just finished.?
Damn I want your front end. I love the new square look.
Sorry, the front end and other assorted parts from that truck are going on the 2000 that’s getting the V8 so it will be a 2005 look alike.[emoji4]
Well they have arrived. It is going to be a few weeks before I can install them because we are getting our doublewide set up Monday and I will have no time for a while to install. I will upload some pics of them later. I am getting an error when trying to do so. I checked the headers over with a flashlight in the dark and did not find any cracked/bad welds.
They look nice! :icon_hornsup:
[emoji106]I can’t wait for the review! I’m thinking of going with a Cherry Bomb Extreme muffler, and would love to install headers at the same time.
I’m planning on removing the drivetrain from my Ranger next Saturday, I’ve been helping my friend (where my Ranger is) clean out his barn (30 + years of car parts) the past few weekends.
Yeah it sucks I'm going to have to wait a little while to get them installed.
I know they said it is tight getting them in there. When I was in the process of removing the 5.0 out of the explorer it was tight getting to the exhaust because the way the fender wells were made. I had a ton of room when I dropped it in my ranger. The passenger side I just reached through the fender well and tightened up the collector bolts.
I finally found the time to remove the V6 & automatic trans from my Ranger.[emoji4]
Plus everything else LOL
Yep, I may have went a little overboard. But now fitting the V8, 5speed, transfer case, drive shafts and exhaust should be a lot easer.[emoji41]
Craig, did you have any trouble with the condenser fitting into the Ranger? I had a little time on Saturday to continue working, but it definitely won't drop in. The plastic brackets on the outside of the condenser interfere with the metal arms going vertically down to the trough that the condenser rides in.
I think you use the Ranger condenser, here’s the list of parts you’ll need from the Exploder and no mention of the condenser, only the A/C lines.
A complete Explorer with a 5.0L AWD would be the best place to start. If not, you'll need these parts from a 5.0L Explorer:
Complete Explorer 5.0L engine with all accessories, wiring and computer
Battery cable harness
Cruise cable
Throttle cable
Radiator
Radiator hoses
The high pressure power steering hose
A/C lines
Exhaust manifolds and Catalytic converters
Transmission and transfer case
Airbox, MAF, and Zip tube
Fan and shroud
Motor mounts
Fuel pressure regulator
