capridude
- May 23, 2008
Trying to smog '87 Bronco II 2.9 5speed 4x4.
The engine is self-rebuilt with 33k miles. Replaced/renewed almost everything.
The idle vacuum is 15", steady. Used to be 20". Even-misfire at tailpipe.
Ignition timing is correct. Valves are quiet, seem to operate fine, lots of oil.
Fuel injectors all work fine. #4 cylinder has lower exhaust temperature (210)
than the others (300-400). Removing #4 fuel injector electrical connector has
VERY little effect of engine running, maybe a drop of 0.5" vacuum. That cylinder gets same spark as other cylinders (but they all seem a weak yellow).
#4 compression is 75/120psi (first pulse/fourth pulse), while neighbor cylinder
#5's compression is 100/150psi.
My only ECU code is 32 (Egr valve not opening enough-- egr valve disconnected for the troubleshooting anyway)
It seems unlikely that one lower cylinder would cause a 5" vacuum drop.
I have two ideas left: failing coil/ignition; and mechanical timing jumped a
tooth on the cam. If it jumped a tooth, would the computer be able to compensate to get a correct ignition timing?
Anybody have any other ideas?!
Cheers, Jeff
Cheers, Jeff
