- Aug 21, 2017
- 2.9 V6
Hi
Thanks all for your recent help regarding the engine bogging. I got that sorted and it was running better than ever.
Then, out of the blue, I got in to use it and the clutch pedal had zero pressure, and it wouldn't go in to any gear (it will engage any gear with engine off, so presumably not a gearbox issue).
The pedal comes back up, but it feels like it's not connected to anything it's so easy to press.
The level in the reservoir was fine, so it isn't leaking fluid (or if it is, then it's a tiny amount - the truck is greasy as h*ll underneath so tricky to spot any new leaks, but there was no spot on the ground).
I tried bleeding but this had no effect. I will have another go as I was using a new-fangled bleeder that actually made it harder, so will try again with a bit of hose and a one-way valve. But if it is air in the system, then it must have come from somewhere.
It had a new clutch and new genuine Ford slave about 2 years ago and has been fine with regards to the clutch since then (until now).
Can a slave be faulty without leaking? I put it in gear and then switched the engine on and it would drive, so the hydraulics appear to be at fault, rather than the plates. Are there any tests I can use on the slave before dropping the gearbox?
The brakes seem fine, which suggests to me that the master is OK, but again - any tips on how o test this before buying a replacement?
Many thanks.
Many thanks.
