Zapper
Yes i can afford this without "daddies money"
- Mar 12, 2019
- Age
- 21
- Buhl,ID
- 1986ish
- 2.9 V6
- Manual
- Total Drop
- shot bushings?
- Tire Size
- 235/75/r15
- My credo
- To send it or not to send it, that is the question.
so my 1986 2.9 has been consuming roughly a quart every 150 miles, so about a quart every week i have replaced the valve seals due to them being crusty and not really doing much to seal and it lessened the smoke a lot. But it is still burning pretty bad, i checked compression and i have about 110psi on all 6 cylinders, at idle it hazes a decent amount and when engine braking or just decelerating it just bellows smoke out of the exhaust after a few seconds, if i tap the throttle it lets out a large cloud, and under heavy throttle at 4000+ rpm it lets out a consistent cloud of blue smoke and somehow it isn't fouling out the sparkplugs i have looked up a couple TSBs on alldata and one that caught my attention was about the intake gaskets but i couldn't see that being the case since my plugs are clean. my 2.9 does have the factory early design cylinder heads that have a ford oval casted on them next to valve spring and i wonder if it is possible that they are cracked and allowing oil to escape into the exhaust. so does anyone have any other ideas, no it is not pcv related since it does it even when it is vented to atmosphere and Egr is fully blocked off and disconnected at the electrical plugs and vacuum is disconnected to it because it kept pissing off the 1991 2.9 ecu i put in it.
