2.9 Sierra vs. Ranger Intake Comparison - Side by Side Photos
PetroleumJunkie412
Officially missing
Dirtman's Basement
Give 'yer balls a tug. Fight me.
Just thought it would be interesting to see the difference side by side.
The 2.9 throttle body is the an '86 57/58 mm
Holy shit.
That TB from europe is damn near double the flow of the american one.
You can definatly tell though the american 2.9 was designed to flow better at lower RPMs though.
Lovin the 2.9 porn though.
Here's some more for ya, then. Nudez and all.
Side by side of a UK (VAM, possibly MAF, just going by DTC codes it gave when I ran it on my 2.9) and an American speed density ECU. American is on the left, UK is on the right.
Front label of the UK ECU
All of this made possible by @kunar. THANK YOU!
The UK ECU was from an auto; tripped a bunch of DTC codes when used about shift solenoids (my truck is a manual). Thanks to some old posts by @RonD, I think I figured out a way to simulate the shift solenoids by using two 30-40 ohm resistors in the transmission harness, each run from the 12v wire to the EEC grounds.
Figured it would be worthwhile to get these photos up for posterity's sake, if nothing else. For the life of me, I couldn't find a side by side comparison of the two.
The only other curiosity is the UK ECU also tripped DTC codes in reference to vane air meters. That seems odd to me. Photos below are in reference to a UK 2.9 with vane air meters, and a screenshot of a parts reference showing dates of manufacturing for the UK ECU
So... How much is interchangeable? How does the European model compare to the American model, performance wise? If it nearly doubles air flow, does it have bigger headers to handle it?
I guess the most important question is, how available are parts here in the US?
You've got my curiosity peaked, that's for sure!
So from what I can tell, there's a few subtle differences. Most striking is the TPS shaft appearing to be completely different.
The UK plenum is also fully walled down the center, with the exception of the port in the throttle body and a small port in the back. Not sure of its function yet.
Edit: port in the rear is for the UK fuel pressure regulator.
Other than that, the bolt pattern is different in one position. Looks like we finally figured out what that extra tab is on the upper intake gasket.
As soon as I source another air hose and filter, it's getting put on.
Just going from wiring diagrams I found and need to scan and upload, the computer's primary difference seems to be that it accepts dual vane air meters. Discussion with a few Ford guys overseas is eluding to an interesting conclusion that with this computer, it is possible to run dual MAF sensors in place of the vane air meters to have a true dual throttle body setup. Definitely need some ECU experts to chime in on this, though. Here's looking at yinz, @deathbypsi and @adsm08
Bone stock the Sierra 2.9 was rated 18hp above the Ranger 2.9.
If I can get a dyno day, I really want to put these head to head. My heads are aftermarket and ported, and I'm running JBA headers and a 2.5" exhaust, so the results may be a bit skewed compared with a stock Ranger engine.
A few resources on the UK ECU.
Not precisely correct, but a starting point.
The UK ECU has an additional edge board connector... What is that used for?
No idea.
Some context that may give clues, though.
When Ford originally built the 1987 Sierra RS500 2.0l Cosworth for Group A rally racing, they bolted a second fuel rail onto the engine, complete with injectors that were deactivated in the road cars that were sold to the general public. These injectors were on the production models so that they could be on the race versions as well. For rally racing, they simply activated the second set of injectors.
The Sierra was the same model group as the Merkur Scorpio, Ford Granada, Ford Capri, and Ford Scorpio. All of these used the 2.0 or 2.9 engines. Our Rangers share so many similarities that I did no modifications to my Ranger's wiring, plugged the UK ECU in last night, and it ran. It would have been such a beautiful thing if they would have offered a Ranger Cosworth.
It would not surprise me if the 2.9l ECU had something similar built in for European rally. Seeing as how Ford Germany would occasionally slip components into production models so that they could use them in competition, I am highly suspicious that this is a similar trend.
Another thought is that Cosworth also put their hands on the 2.9l for the 24v version. Depending on the true year of the ECU, it's possible that the extra edge card is for Cosworth versions only, but I am unsure.
There's also the possibility that Camco modified the ECU with a port for "something." they were a well known performance shop in the UK that specialized in Ford.
I am fervently researching as best I can to figure it out. The most striking thing between the two was the upgraded chipsets to Texas Instruments components, and the overall build quality.
There's more than likely something suspicious going on with it. Back in those days Ford was going up against Audi, Porsche, Lancia, etc. in rally and winning. It seems unlikely to me that this is just a fluke, or doesn't have a purpose.
There's a reason I didn't "put a 4.0" in it. They never built a 4.0 Cosworth. :icon_thumby:
Interesting stuff... Makes me wonder a bit why the second set of injectors? Fuel enrichment for forced induction? Entire back up fuel system? Volumetric efficiency thing? Hmmmm
I just didn't see it on the schematic you posted... and had to ask.
UK ECU part number photos for the part number snobs, er, um, experts out there.
Just on a cursory Internet search, it looks like this is a forced induction capable computer.
E9 would be a suffix for an 89 ECM.
I wonder if there were differences in the euro early 2.9s and later ones like in 'murica.
I am super interested in this...
Read the description....claming 500hp.
Once again, just for posterity's sake, figured out the reason the Sierra computer idles rough/crappy is the base timing on a 12v 2.9l Sierra/Granada/Scorpio is 14 deg. BTDC vs. the Ranger ECU at 10 deg. BTDC
