kimcrwbr1
Isn`t wiring fun. well it is for me unless I need to drive the vehicle with wiring issues. Did you get it running good yet. Have you run a compression test and checked the vacuum pressure. Check the compression after the engine is up to temp pull the plugs and crank on each cyclinder untill the guage stops moving usually two or three revolutions. write the numbers down depending how old the motor is the the most important is they are within 5% between the high and low. Good job on the harness did you give the connectors a shot of dielectric grease when you plugged everything in. Now you know the wires are good I will make it alot easier diagnosing any issues you may have.
